TwinTurbo.NET: Nissan 300ZX forum - Re: fluid has max velocity at center and ZERO velocity on ed
Subject Re: fluid has max velocity at center and ZERO velocity on ed
Posted by kZtt (zedparts.com) on February 21, 2002 at 4:08 PM
  This message has been viewed 75 times.
In Reply To fluid has max velocity at center and ZERO velocity on edges> posted by my91z on February 21, 2002 at 03:47 PM
Message um... I know most flow equation solutions prefer boundary flows. That's because inter-particle interactions and velocities are lowest and that means that's the lowest energy solution. What you say makes sense, but why would the boundary velocity be zero? That assumes a particular boundary condition that does not appear to apply if, say, the surface is approximately frictionless... I think a discontinuity in the velocity is allowed at the boundary since this is a interface between two different materials... isn't fluid flow a second order differential equation? So you really only need continuity on the second order derivative, and velocity is the first order derivative...
Am I completely off base here? My memory isn't that great and I never really took fluid mechanics...
